Seeking advice if this would be a good inverter to power my submersible well pump, or if there is a better solution. Please let me know any first hand knowledge you have, if you have a similar setup.
I currently have a 400' deep well, and just ordered a Grundfos 1.5Hp, 240V, single phase pump, model 15SQ15-290. Initially I plan to run the pump intermittently powering it with a generator to fill a 2,500 gallon tank that I will drawing from. The well is about 500 feet from where I have my living area/RV. I currently only have a small amount of solar mounted on my RV and have plans to install a medium/large solar system in the future - but not sure when that will be. But for now, I would like to get the well producing so that I can start watering a garden, trees, plants, etc.
So, hopefully someone on here has already tried this inverter with a similarly sized pump, and can give a thumbs up or down, and some advice.
Thanks!
Patrick, part of the resistance living in occupied California.
Growatt 2.2kW 3HP Solar Pump Inverter l Water Pump Inverter | Grid-Assisted | SPI 2200TL2-HV
(non-affiliate link to the inverter: https://signaturesolar.com/growatt-2-2kw-3hp-l-spi-22000tl2-hv/)I currently have a 400' deep well, and just ordered a Grundfos 1.5Hp, 240V, single phase pump, model 15SQ15-290. Initially I plan to run the pump intermittently powering it with a generator to fill a 2,500 gallon tank that I will drawing from. The well is about 500 feet from where I have my living area/RV. I currently only have a small amount of solar mounted on my RV and have plans to install a medium/large solar system in the future - but not sure when that will be. But for now, I would like to get the well producing so that I can start watering a garden, trees, plants, etc.
Thanks!
