Hello everyone, thank you in advance for your help.
I want to create a DC solar water pump setup but need help matching the components. I want to pump water from a stream to a storage tank about 10 meters higher. I know that it will only be able to pump for the four or five sunniest hours in the middle of the day. That is good enough. I will attach a picture of the 24v charge controller box I am looking to buy. The pump I am looking at is 24v 330w DC. From my understanding, the startup of the pump needs more than the 330w and solar panels don't put out the maximum rating except under ideal conditions. So I was thinking about getting a 500w panel. The store I am going to buy the charge controller said I should buy 350-400w panel but I am concerned it won't be enough. The 500w panel is rated 48v. The other two components are rated 24v. I just want to make sure that I match everything up correctly. Any advice or education is much appreciated.
