L LydMekk Call me Icarus Joined Apr 9, 2022 Messages 905 Location Spain Mar 25, 2023 #41 Chickens. I'm charging with 3.55.
F Futureman New Member Joined May 28, 2022 Messages 8 May 5, 2023 #42 Chris_S said: Getting ready to calibrate the capacity on a 200A seplos BMS. How am I going to set my inverter to reach bms cutoff? Do I set shutdown on the inverter to 0%? Click to expand... I have seplos battery 200 amps from china but the bms read only 120 can you explain that
F Futureman New Member Joined May 28, 2022 Messages 8 May 5, 2023 #43 I need the adapter wiring diagram from china seplos 200 amps bayyery to the pc
houseofancients Solar Wizard Joined Nov 29, 2019 Messages 3,940 Location EU May 5, 2023 #44 Futureman said: I need the adapter wiring diagram from china seplos 200 amps bayyery to the pc Click to expand... the manual is in the resources section of this forum
houseofancients Solar Wizard Joined Nov 29, 2019 Messages 3,940 Location EU May 5, 2023 #45 Futureman said: I need the adapter wiring diagram from china seplos 200 amps bayyery to the pc Click to expand... by default seplos caps a single bms to .5c. this can be changed in the pc / bluetooth software
C Chris_S New Member Joined Feb 28, 2023 Messages 60 Location South Africa May 5, 2023 #46 Futureman said: I have seplos battery 200 amps from china but the bms read only 120 can you explain that Click to expand... Be sure your cells are rated at 1C
F Futureman New Member Joined May 28, 2022 Messages 8 May 6, 2023 #47 Chris_S said: Be sure your cells are rated at 1C Click to expand... my friend tel me how to rate it to 1c kindly
houseofancients Solar Wizard Joined Nov 29, 2019 Messages 3,940 Location EU May 6, 2023 #48 Futureman said: my friend tel me how to rate it to 1c kindly Click to expand... what cells are you using ? should be in the spec sheet
