kolek
Inventor of the Electron
- Sep 29, 2021
- 682
Battery shutdown is set to 50V. AFAIK, that is the low voltage disconnect setting.
The Deye knows the battery voltage is below 50V, it's reading the battery voltage as 49.2V.
But it's been drawing 0.5A out of the battery for the last 4-5 hours since it hit 50V, leading to the battery to fall to 49.16V.
Went to sleep at 3AM when it hit 50V, at that time it was slowly transitioning from battery to grid and it had reduced drain on the battery to almost nothing. I figured, "Ok, the inverter has only 1 job to do at this point, it will be fine." Wrong.
Woke up to these readings. It never stopped draining the battery even after transitioning below 50V.
Since the Deye cannot seem to figure out it needs to stop draining the battery, I manually have disconnected the battery until I can sort this out.
This is the first time this system has needed to perform a low voltage disconnect, it was connected to the grid for the first time yesterday.
Anyone know what is going on here?
