I was told equalization should be set as low as possible to prevent equalization from happening, was told it should be deactivated for this battery type (standard EVE 280ah batteries) and 41V is as low as that setting will go.
By setting equalization voltage same as float, even if it equalizes it is just floating.
But I would set to same as boost.
Here is the discussion I had with someone in private messages:
"Equalize , the function, is only used for lead acid batteries, it will damage your lifepo4 cells, therefor it should be set to 0"
Me: "Unable to set equalization to 0. Lowest it goes is 40V."
"Depends on the firmware that your unit came with.
Setting it to 40v is fine too"
Equalization time is what should be set to zero.
Ok just got some mind-blowing information from
@XO4001 via private message. He says that this is "normal" behavior for the Deye.
He says you need to set your shutdown voltage higher because even if you go below your shutdown voltage,
the Deye inverter will continue pulling 50-70 watts out of the battery essentially forever, regardless of whether it's below the shutdown voltage setting, and the only way to stop it is to disconnect the battery or have your BMS step in when the voltage gets too low and shut down the battery.
INCREDIBLE if this is true. Is this normal behavior for inverters in general?
Is your inverter still producing AC, and drawing whatever wattage loads represent?
Or is 50 ~ 70W its standby draw?
My Sunny Island will consume 25W no-load, plus whatever loads demand.
In "standby" with no AC output, it draws 4W, that we can live with for a long time.
It may actually shut off at some low voltage, I've seen screen go blank.
Default operation is to shut off inverter (whether 4W or 0W I'm not sure) and 70% DoD (lead-acid), and low voltage probably triggers that regardless of actually kWh drained.
Default is to shed loads (assuming contactor wired to them) at 80% DoD, leaving inverter running and critical loads powered. That lets it restart everything on its own after charging up from PV in the morning.
If battery does get too low, Black Start requires user intervention.
Sounds like a higher voltage or SoC shutdown level is what yours needs.
