Texas-Mark
- Aug 4, 2021
- 1,284
I have two identical non-smart 12V 100ah lifepo4 batteries. I had a couple of spare Daly BMSs with BT laying around so I swapped out the existing BMSs. One of the Daly BMSs is 100A and the other is 60A. I needed to do a test with a new inverter, so I put the two batteries in parallel with 2/0 cable. Both batteries were fully charged. The inverter was drawing 36 amps from the pack. However the 100A BMS was showing a 22A draw and the 60A BMS was showing 14A. Would this be due to the 100A BMS having less resistance? I would think that at this relatively low draw, they would be closer, despite the different ratings.
Side notes. Both batteries have stand alone active balancers, so there is no top cell imbalance in either. I also swapped the battery positions, not that it should really matter with 2/0 cable and such a low current draw. Of course the 60A BMS has a lower gauge wire, but again, there is not that big of a draw.
