I have an Epever 24V 2000W inverter that draws 12+ watts on standby. Is there a way to automatically disconnect or power down the inverter when the battery is below a certain level. I don't even see an automatic shutdown voltage in the spec sheet so I am not sure how to control the inverter. If my appliances run the battery down and then there is no sun for a couple of days will the battery just drain until the BMS shuts it off? Seem like there has to be a way to control the inverter based on battery level but I don't see a way. This does have a RS485 port, but I am not sure I can power on off with it? What about a some kind of relay, I have seen it mentioned but not sure how it would work.
