Hello, I'm looking for some help. I'm planning to wire my inverters to a distribution box. I've seen some of the videos out. I don't see them wiring to a box that has a Main Breaker like a 100amp or 125amp. Why don't they use a main breaker? My thought is the breaker can be used as a cutoff switch. Another question is about the distribution box. I also see in the videos that they combine the ground and neutral wire to the same bus bar. I can see them doing that in a mobile application because there isn't a true ground. On a house system why wouldn't you have a separate ground bus bar and ground to a earth ground?
Thanks guys,
MrHavasu
Thanks guys,
MrHavasu
