So I wonder if it's possible to build a hybrid battery, maybe 20x 12v 10ah batteries in series? Based on Dr.Prius, an app that shows battery voltage, and charge/discharge information, I found the battery in my 2009 Prius normally ranged from 230v to 270v depending on its discharge/charging state and amperage, and the max discharge amp I have seen is 50amp. The max charging amp is 70 amp. Is it possible to mix and match 12v lifepo4s or cells to make a Prius battery? Or even convert it into a PHEV and charge off solar.
