I am building battery bank consisting of 16 eve 3.2v cells in series 16S, back to back in 1 row in series configuration. No BMS. INITIAL VOLTAGE WAS 51.7V. I hooked it up to my 5000w eco-worthy solar inverter and 5 400w solar panels.
Next thing I know, the inverter stopped charging, saying the battery is full. I knew that was not possible because the initial voltage was 3.2 V on each battery And it had only been hooked up to the inverter for about 20 minutes... The battery was now reporting that it was 57.6v...
I then checked each cell and 11 were only 3.3 volts average...the other 6 were 4.4v. Ouch. I immediately disconnected the battery from the charger.
I then separated the batteries and put 2 cells in parallel with one of the cells being the overcharged cell. I successfully revived the other 6 cells back down to 3.3 volts. Yay!
For the life of me I can't figure out why just 6 of the cells got overcharged and the others did not!! Does anyone have an idea why that happened? I thought hooking it up directly to the cells with no BMS would be fine.... Famous last words
