Here is my situation
Victron Multiplus II 48v 5000va unit running 120v critical loads, cerbo GX, using ESS and keeping the batteries fully charged.
EG4 6000XP 48v unit running 3-220v mini splits and one 120v mini split. SBU setting as close as I can get.
One 48v battery bank consisting of 1 server battery, 2x24v in series for another 48v battery, diy 48v battery, all 5.1 kw in size.
One victron shunt load side connected to the Victron busbar - and the other to another busbar with all battery negatives hooked together.
So I want to share the battery bank between the two inverters, I am looking for opinions on the best way to do this, should I choose the Victron to keep the batteries charged, or should I use the EG4? Or both, and limit thier charge currents, the battery bank will ultimately determine when the batteries are fully charged, I am just wondering if anyone has run into this issue before?
I also want to make sure that I position the EG4 cables on the right location of the Victron shunt so it measures the current going in and out of the EG4 as well as the victron.
Thanks in advance![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks in advance
