DIY bms around ESPhome
lyn1337
SE
Has anyone here attempted building a diy bms using a esp8266 yet?
I know there is a daly bms sensor (not sure it works with the daly active balancer, else it would be sort of interesting for me too),
but all I'd like to have is the voltage of a 16s config.
Stuart Pittaway designed a DIY BMS quite a few years ago, see...
and
But do you actually want to do all that? If you're just after cell voltages, you can get those from the UART port of several commercially available BMS's; I use an Overkill/JBD one.
