I would get the 10 circuit breaker box transfer switch ... if for my house, ... and run 240 vac split phase. For this 6 Circuit Box on this project, I reconfigure IN Plug and wiring for 120Vac IN, plus changed the 240vac 20 amp double breaker to two separate breakers / one 120vac 30 amp, and one 20 amp breaker making for 6 x 120vac circuit breakers. Only those two circuits wired for the 240vac Double Breaker have 10 awg wire that can handle 30 amps/ & the other 4 breakers have 12 awg wire. The Supplied Directions were Good. I now understand more how all this works from my DIY install. ... The last 30 amp breaker circuit I will wire from that transfer box is for a GE motor powered 3/4 hp water booster pump that is currently wired for 240vac, with motor config option for 120Vac, at twice the amps, and even more for surge start up.
Re: Automatic: I believe when I get this Battery Wagon w EG4 ... hooked up to its' 30 Amp In and Out Plugs. ... It will function in Automatic Mode by my configuring for 120vac to pass through from grid to power the EG4's AC Out going to the essential home circuits; w the Transfer box switched from Grid IN to GEN IN; ... & left in this mode for automatic. ... Then when grid goes off, my inital testing shows the battery power take over to power the GEN IN to the Essential House Circuits; ... AND ALSO ... When Grid Returns ... The Grid Powers All the Circuits switched to GEN in Transfer Box; PLUS automatically initiates a Battery Charge Cycle (unless EG4 3000 is configured for power saving mode ... mine needed a work around ... more on that later). Configured Grid powered battery charge amps need to be low enough to allow EG4's 3000 Watt ByPass Capability with enough Watts left over for the Essential Circuits. My First Test Cycles after its' new home hook up ... soon .. will be powering all the essential circuits (currently 5/ without 30 Amp Breaker to water pump) that I have already wired to this Transfer box, Leave it switched to GEN IN ... watch Grid power the Home's Essential Circuits working properly; Then Switch The AC 30 Amp Breaker that goes in Main Panel, That is Powering the EG4 ... to OFF, and I will get to witness how long that 15.6 kWh of LiFePO4 Battery Power lasts. From kWh of last monthly utility bill when being frugal, I estimate the Battery could power All Essential Circuits for Two Plus Days. I look forward to what my next Testing Cycle Reveals.
Re Wiring an EG4 or any all in one "Directly" to a Transfer Box Switch, without In and Out plugs: ... I prefer a wheeled setup with 30 Amp Cord and Plugs for the obvious documentation that this is a Portable AC Power Backup Unit (with No Way I currently know about; for needing a Building Permit and Inspection. Being this is for a house I do not own, and I am becoming Tech Support for a friend who paid for the material costs only (which was about $3500 including transfer switch box); ... This Portable Option enhances my comfort level; ... and is Great for easy transport options (that might someday power a music concert at the park, ... for education attention about home power grid back up options). I will be billing for consultation and configuration on my next setup; with goal of help neighbors while staying in my easy going retired options mode.
Re my wiring of that Circuit Breaker Transfer Box: I told my friend I can Do All the Details Properly (even found a 12 awg wire on a 30 amp breaker I updated to 10 awg wire) ... AND if she ever wanted or needed to get a Permit for this Transfer Switch set up; like for possibly down the line, if selling the house?, ... she could hire a Licensed Electrician for an inspection and hoop jumping for that. I am confident of my details on 240 vac Circuit Breaker Panels with a history of doing all the AC Wiring on 3 DIY built Houses (two in Northern California via Building Plans I drew up myself for the Permits. My mechanic shop back in the 80s is also part of my electrical and diagnosis background. This is currently a fun and engaging hobby. I am currently retired. I like help friends. AND ... I Enjoy Learning More, including via my DIY projects, ... All The Time. :+)
