oldmaninsaline
- Oct 7, 2022
- 68
What inverter did you use in there?
I could have gone with a smaller case but wanted to leave room for upgrades. Right now I have a WZRELB 600 watt pure sine inverter (2 years old) in it. Hard on/off switch, not the soft kind so I can kill power to it through the relay. The reason is that it's all the wattage I need right now. 5.64 watts on standby, 10 amps from the batteries at my highest load. I replaced the 40 amp fuses in the inverter with 20 amp for CYA. What I did when mounting it is remove the cover (heat dissipation), bend the mounting tabs 90 degrees to mount it in the case. Then I tapped into the AC out and ran that to the AC outlets in the case, using UL outdoor rated outlets. I used the ground in the inverter and used the AC outlet screws to connect the cables (10 gauge, THHN) per NEC. Hopefully I'll feel like upgrading to a 1000 watt pure sine with terminals to allow for earth grounding.
