bigredball90
- Feb 9, 2020
- 25
Looking at trying to build my first powerbox for camping and backup power for a few things around the house if we loose power. Ive never built a battery pack or anything like this before so I could use some guidance. I want to charge it primarily from 110 from the house, and the van while driving. Ill be camping in a forest so solar wont work well. Id like to be able to "plug it in" to the van to run the fan and lights, and usb ports on it to charge misc stuff. I would really like to have the ability to use it as an emergency jump pack for the van if the engine battery dies. Ill probably add and led flood light or 2 on the box in case I need light somewhere outside. Couple of computer fans to keep the box cool. Whats the easiest way to control them? Temp sensor?
I need 75ah of usable power for a weekend trip. Ill be powering a roof fan, led lights, and charging misc things. Im looking at 100ah lifepo4 calb? for a batteries. Im open to battery options.
I saw somewhere someone used a large anderson connector to alligator clips for jump starting batteries if needed. How do I figure out the cable size for that? I think I can use an anderson connector to plug the box into the van for the lights and fan.
List of things I know I need: BMS, battery isolator, charge controller, 12v to 110v inverter, fuse box, 2 small fans for case.
Thats all I can think of for now, any help or insights would be great!
