This would be in conjunction with the main Lead acid starter battery so in theory the pwm drain from the alternator shouldn't cause too much of an issue?
It's a bit beyond my knowledge set but It's interesting to hypothesise about these things..
If you have a lead acid connected first I would say it should work and would surely be more efficient than most of the other solutions. I'd say give it a try with a cheap pwm controller, these are almost free these days anyway
Just make sure that when you first connect the pwm controller to the lead-acid bat, the voltages of the lead-acid and the Lifepo4 are very close. If not there will be a current through the controller that it probably was not designed to handle...
This was my conclusion too. the more I think about it, a PWM controller is basically just a transistor switching on/off.
There is nothing to limit current (as mentioned above) so I don't think it would be a good idea. if the alternator could give 80A and the battery could draw 100A, but the PWM can only handle 20A... I think it'll go POP
