Rabbit
- Nov 19, 2019
- 85
I'm about to build a 12-volt 280ah battery with cells from one of Mr. Prowse's current favored Ali Express sources, using a 250 ah Daly BMS. I don't have a hobby-charger or any of the relatively specialized bench-gear I see others using to top or bottom balance, and don't want to buy any given that I'll probably only ever use it once. I don't need anything even remotely resembling 100% performance from the battery from Day One, so can I wire it up without cell-balancing (assuming the individual cell voltages are very close) and count on the BMS to slowly balance it? If so, should I leave it connected to a (proper, good-quality LiFePO4) charging source? I have one of these, since I already own several "drop-in" LiFePO4 batteries. Thanks!
