burgerking
This is the 3P power provided by the Utility Company to a certain neighborhood in Manila, Philippines.
L1-L2 = 240V
L2-L3 = 240V
L3-L1 = 240V
NOTE: L3 to N is 208V, But L1 to N is 120V, L2 to N is also 120V
Some houses receive 3 wires, either L1L2N or L2L3N or L3L1N.
My apartment compound has all 4 wires.
We do not use Neutral for power. We use it solely for grounding appliances - it is by local code to bond N to a Grounding Rod.
So I connected my Inverter's (Deye) PE terminal to Ground.
I also connected L1 and L2 as shown on the L and N terminals.
NOTE: All PE in this terminal block are connected to each other and also connected to Case.
Here is my Question:
It was said that during a Utility Outage, I need to disconnect Utility's Neutral to Inverter's Neutral.
BUT all PE are connected on this terminal.
Likewise N on this terminal is connected to L1 (not N).
What now?
L1-L2 = 240V
L2-L3 = 240V
L3-L1 = 240V
What now?
