Hi All,
I have a 3.3kw array split into 3 x 1.1kw series in parallel which then tie into a surge suppressor which is connected to a physical earth pit a few feet away on a 6 gauge copper cable. The live cable runs 120ft to a 50 amp breaker and then to the inverter which is connected to another physical earth pit a few feet away. Then the 220v ac power runs to the main breaker in the house which in turn is connected to a third physical earth pit about 25ft away. I was advised not to ground the solar panels as it will attract lightning and should instead install a lightning protection rod on a pole connected to a separate earth. Where would be the best place for this rod?? A high location? How far?
I also read that I should install two surge suppressors before the inverter due to the long cable run but was advised against it by the local engineer who sold me the breakers. Should I install the second surge suppressor? Where should it go? Before of after the breaker?
The ac cable run is about 80ft from the inverter. Should I install two surge suppressors on that line? One close to the inverter and one before the main breaker?
Given that I'm in Yucatan and the lightning is very intense from June to October, should I install two lightning arrester rods?
Any help I can here is highly appreciated as I'm terrified of lightning strikes. Is my setup overkill or could it attract lightning? I have 6 gauge cable connected to the earth pits.
Thank you!
Thank you!
