Ok I thought it was split phase inverter that runs on up to 500V DC bus. It looks like PV- will have -250V square wave with potential peaks into -400V from ringing. Would really have to measure it with a scope to be sure. You may be able to use lower voltage MOVs for better protection.
I like PCB idea. Just make sure diodes point in correct direction and place them on a heatsink. I am not sure if diodes will offer protection the way I imagine. I need to think about it more.
Just double checked the forward voltage of high current schottky diodes vs standard diodes. I'm a bit confused, but it looks like that at higher current (at about 15A), a schottky diode has a higher forward voltage (between 2-3V) compared to standard diodes (about 1.2-1.5V)?! Only at low current, the forward voltage of schottky diodes seems to be lower.
I thought I remembered that Schottky diodes has less forward voltages (beside higher speed) compared to standard diodes (e.g. 0.2V-03V instead of 0.7V). To reduce power loss and implement easier cooling, this was my first idea. But I've found, that the lower forward voltages of Schottky diodes are only true for low current in the mA range. At higher current like 10-20A, it's vice versa and the standard diode has lower forward voltage (2-3V compared to 1.2-1.5V).
I only found view Schottky diodes with a high DC blocking voltage Vdc between 500V-600V. And these high voltage types have a lot higher forward voltage compared to low voltage Schottky diodes (at about the same current between 10A-20A). It looks like for PV switching the Schottky diodes are not ideal because of the high string voltage requirement. So I think, in this case classic diodes makes more sense and they are cheaper.
