Quincy1234
- Jun 11, 2022
- 6
I have 5 of them.How many panels do you have?
That sucks, the Ecoflow Delta Pro has a max VOC of 150 and a max of 15 amps (this seems seriously low does anyone else know if this is accurate). You would be able to connect 2 of these in series to it maybe 3 but only if it's above 41 degrees.I have 5 of them.
That's kind of what I was thinking but I didn't know if there was a way around that with some combination of series and parallel. Like I said, this is all new to me.That sucks, the Ecoflow Delta Pro has a max VOC of 150 and a max of 15 amps (this seems seriously low does anyone else know if this is accurate). You would be able to connect 2 of these in series to it maybe 3 but only if it's above 41 degrees.
Those panels should work fine assuming you have 2. It's likely a bad connection somewhere.Bought a Ecoflow Delta Pro and a couple Rockpals 100w folding panels. The Rockpals panels come with Anderson connectors so I bought an MC4 adapter When I take everything out into the sun and hook it up, the Ecoflow doesn't register any solar input... anyone know why? Is there a reason they aren't compatible? I can't find anything online.
Thanks, maybe I'll get a different Anderson to MC4 adapter and see if that changes anything. I was getting a reading with my multimeter though, so I though it might be related to compatibility.Those panels should work fine assuming you have 2. It's likely a bad connection somewhere.
Compatible isn’t the issue. It doesn’t know the brand of the volts.Is there a reason they aren't compatible
?Those panels should work fine assuming you have 2. It's likely a bad connection somewhere.
Where did you measure it with the multimeter? You should check right before the Ecoflow to make sure that the issue isn't in a connection before that.Thanks, maybe I'll get a different Anderson to MC4 adapter and see if that changes anything. I was getting a reading with my multimeter though, so I though it might be related to compatibility.
Wouldn’t the low angle of the sun and 41° Temperature in the fall and winter time lower the volt output of the panels? This is a question I have and I think we can over panel the delta pro in the winter time because the sun is at a far southern angle. Just my thoughts.That sucks, the Ecoflow Delta Pro has a max VOC of 150 and a max of 15 amps (this seems seriously low does anyone else know if this is accurate). You would be able to connect 2 of these in series to it maybe 3 but only if it's above 41 degrees.
It's actually the opposite, the lower the temperature the higher the VOC gets. Hense why if they wanted to do 3 panels it would have to be above 41 degrees.Wouldn’t the low angle of the sun and 41° Temperature in the fall and winter time lower the volt output of the panels? This is a question I have and I think we can over panel the delta pro in the winter time because the sun is at a far southern angle. Just my thoughts.
