Ecoflow River 2 Max discharging without any load
mxgoncharov
Ukraine
Hi all ?
I’m newbie here and don’t understand all details about how inverters work.
But I have a situation.
I’m happy owner of River Max and River 2 Max.
The issue is capacity draining.
When I turn off AC sockets on River 2 Max it says that in such condition it will work for about 30-32 hours.
With really simple math (512wh/31=16.5w) I found that it uses 16.5 watts for smth.
Also when there is any load on sockets this difference goes up to 20-25 watts.
If I’m understanding correctly inverter might take some percentage of load, not constant value.
So here is a question. Is it okay?
Should it take so much power for “nothing”?
I can’t imagine what might need so much power inside those cutie brick.
Thanks in advance
The electronics consume a little bit.
I wouldn't think it would be that much. Unless the fan is running.
Without load fan is off. No noise, no ticks, nothing
A bit warm top and battery draining )
I’ve asked friends about their experience and 4 of them see 99hrs there without such effect and 3 told me almost same numbers as I have
My river pro just says 99 hrs, also.
Wasn't sure if the river 2 max would be the same.
