ilikesun
Can someone explain the function of the start discharge setting of the 18KPV? The manual states that the range is 50 to 100 watts (default is 100). Does the inverter switch over totally to handle the load at that break point or does it share or handle anything over the set value? Can the value be set higher... much higher... say 250 watts?
I'd like the grid to handle all the light loads and have the inverter and batteries handle the occasional high load during non PV hours.
Thanks.
Thanks.
