wingedlizard
I am moving from growatt 3000 to eg4 6000 xp. I would like to put the EG4 in bypass mode when I charge my EV ( run grid through the EG4 to car charger), But I'm not sure how this works. Is there a simple setting ( Web, Mobile, control panel) that I can manually change this.
It seems like the unit will do this automatically, but even at low EV charge rates ( 240v @ 8a ), My battery either cycles or gives out before the charge completes ( takes about 12 hours at the low charge rate).
My EG4 grid AC in as 50Amps and my car charger usually runs at 32amps, so my thought would be to switch it to bypass, and start the car charging, then switch it back when it is finished.
Currently running with 1 EG4 LL battery ( 100ah) . My other batteries (48v @ 150ah or 24v @ 300ah) are used with the growatt, they are not EG4s, but I plan to move them over when I switch inverters.
Thanks
Thanks
