Hello nasadave!
The reason I'm trying to use UPS mode is the switchover is supposed to be faster if AC power is lost. There's been some discussions about how long that switch over takes, but I know in appliance mode, sometimes everything shuts down for a millisecond during the switch.
I was hoping to see if UPS mode solved that problem.
As with all these infini inverters, the actual specifications are rather lacking on the actual details of how different functionality is implemented. All I can see in theanual is that UPS mode has a stricter voltage requirement... Which obviously begs the question of why?
If I were engineering this, how I would implement UPS mode would be to separate input and output power, so that the output is always running off the battery, even when the charger was charging the battery. That way, if ac power dropped, the charger would go to zero but the output would stay nearly the same.
But, no one asked me to build this system. And whoever did clearly didn't document it as well as I'd like.
Also, if it's not working as designed, I'd like a replacement they does work as designed. Hence why I was asking how UPS mode is supposed to work... If this is 'normal' behavior then I'll live with it. But I hope that's not the case.
Edit: also, my goal is actually to use batteries between (at least) 1pm and 7pm to avoid the high price time of time of use pricing. I was/am hoping UPS mode is similar to a computer style UPS. Does no one use that mode?
