So with your 6 batteries at 100amp a piece for a total of 600Ah with three inverters for a minimum of 200ah looks like you can crank yours up easily to 280amp to start. To a max of 420.With two inverters, I would make sure that the discharge current limit is adjusted for parallel use to avoid the EPS overload. This should be set to 280a. However, the 6000XP recommends a minimum of 200Ah per inverter so I would set this to the max discharge current of 200A for the one WallMount battery.
This is what EG4 sent me.
