ScrotusGobbleBottom
The manual references "Working Modes" But I have not found any documentation on how to change or test these settings. Searching the pdf manual for "Bypass mode" I get nothing that will help me change to it...
It appears I am stuck in off grid mode and this is not ideal. I am not looking to export power. I would like the ability to access the working modes listed in the manual. How do I enable bypass mode when there is not any EOD event. I need to be able to change this setting remotely. I got bypass mode to be enabled by adjusting the "on grid EOD voltage just now, But I cant find a way to turn it off! Now it is stuck on bypass. I have tried adjusting the on grid EOD voltage back to where it was and it did not stop it. Later it turned off bypass mode after 2 hours for unknown reasons. Anyone know how to turn bypass mode on and off?
The manual states:
"Equalization Voltage(V): Range is 50-59VDC for lead-acid batteries. When using Lithium batteries in lead-acid mode, this should be set to 0 (zero)"
You cant change it to Zero..... it will not "set"
ALSO, You cannot even access this setting or any of the equalization settings or even know they are there on the web page or the app when internet is available. You can ONLY access this setting when connected to the dongle in TCP or bluetooth mode (didnt look on LCD). That is strange and potentially unsafe as the default is 58.8 and could be far too much voltage for some systems.
In the manual it mentions "PV Grid Off" It doesn't say how to switch to that mode. This would be very useful for a water heater..
Are the modes all automatic pertaining to what is connected?
EDIT: For those of you with the same confusions:
All modes are automatic. I toggle bypass mode by adjusting the voltage set point to trigger bypass and then move "AC charge based on" to "empty" to stop it. For bypass mode to stop on its own it needs to see a rise of 3 volts past the bypass start voltage.
The 6000xp works well with solar assistant using "luxppower" settings and connecting to the access point on the 6000xp.
The manual states:
