John Frum
Tell me your problems
- Nov 30, 2019
- 15,230
Next time you are on site then.I'm not on site right now, it's an 89 classic coachman 5th wheel. I wasn't able to find a manual on my phone yet
I was able to get the manualNext time you are on site then.
Did the pictures help with what you were looking for? [I hope this will also fix my 12v system from "flashing off and on"]Next time you are on site then.
Partially but not completely.Did the pictures help with what you were looking for?
First I'm hearing that your 12 volt system is "flashing off and on".[I hope this will also fix my 12v system from "flashing off and on"]
Hmm darn trying to do provide as much as I canPartially but not completely.
Yes old sealed lead acid suuuper Dead, 12 years old probably the reason right there.First I'm hearing that your 12 volt system is "flashing off and on".
Is there a 12 volt battery attached to the system?
I need the pictures I asked for.Hmm darn trying to do provide as much as I can
It would be great to get a picture with the door open and internal cover off so that we can see the dc_distribution panel lugs.Yes old sealed lead acid suuuper Dead, 12 years old probably the reason right there.
Okay I will make plans to go take pictures soon as I can.I need the pictures I asked for.
I want to know if the converter is connected to a breaker.
I also want to know its dc amp rating which is usually encoded in the power center model number.
Since your trailer is stationary I suggest we disconnect this battery at the dc load center and connect the new dc2dc converter to the exact same lugs that the battery was connected to.
Brilliant ?If the ac2dc converter has a breaker we can just switch the breaker off and leave the ac2dc converter for emergency backup.
Not sure if you saw this edit. Thanks a lot for help and patience ? ☺ Super greatful I really look forward to having a reliable and expandable setupIt's currently wired 12v battery with panels in parallel, I will be going lifepo4 48v and series
Note, when generator is on, no flashing
Oh crap, what have you done?Not sure if you saw this edit. Thanks a lot for help and patience ? ☺ Super greatful I really look forward to having a reliable and expandable setup
What do you mean? This is how it's been for 10+ yearsOh crap, what have you done?
Your solar panels should not be directly connected to the 12 volt dc domain.What do you mean? This is how it's been for 10+ years
Hmm idk if I'm understanding.Your solar panels should not be directly connected to the 12 volt dc domain.
That is not what you said.My panels connect to a cheap mppt that charges my 12v batteries, the 12v battery goes into victron inverter and powers my loads.
The 12v battery is directly connected to the 12v RV system aswellThat is not what you said.
