System is two 6500s in split phase. There have been two replacement "events", all under warranty.
System startup to first failure: 3 months. Both units failed with shorted DC inputs.
Startup of replacement units to second failure: 7 months. 2P2 inverter exhibited a failure of MPPT1 input.
Since 2P2 inverter replacement: 2 months.
I didn't have any operational issues with the system until the 2P2 inverter. I now have the flickering lifht problem as well as some strings of significant dropouts of the 2P2 AC output. A typical string will have ten or so dropouts and fast returns for a period of 20 seconds or so. These happen three or so times a day. This inverter also has an output voltage regulation issue in that the voltage will swing as low as 108V and as high as 132. The other is rock steady at 120.
