EscapedAritst
I have two similar systems at two different locations that are acting the same. I'd love for someone to tell me what stupid thing I'm doing wrong.
The under performance is that neither of the two systems will provide more than 4kw (between the load and the battery recharging) during even the sunniest hours. I will post a Solar Assistant graph for today below. It seems that if I have 16kw theoretical power available from my 36 455w panels that I should be able to charge my batteries and service my loads at a minimum of 10kw or so.
I understand that after noon (the cliff in the graph above), my batteries are full and I have no need for the rest of the day, but when the batteries are at 50% SOC, I expect to draw at least 10kw to be filling them when the sun is shinning. During the rainy season, there will be days with just a couple of hours of sun and I don't want to have such low performance. I've searched the inverter settings for what might be wrong and the only setting that I can see is #2. I have that set at 70 amps which should be able to supply 3360w per inverter before topping off. But, I'm getting 3000w from all four inverters according to the graph. Hmmm...
The other question is what are those spikes about at 9:30 and 9:45? I get those a lot and some days a lot more than others. There are no clouds at all.
- 36 panels 9s4p generating about 350v to 400v and rated for 455 watts each panel (ideally would add up to be 16kw)
- Panels are due south without shade. Set at 9 degree tilt as I am at 9 degree latitude and have no summer/winter bias
- 4 EG4 6500ex inverters with one string per inverter
- 6 Lifepower4 batter in a rack (soon to be 10)
- Solar Assistant
