Balrog006
Hey folks-I have a battery charging wiring question for you here in the know.
I have 2, 6x racks of EG4 Lifepower 4 batteries (60kWh total) with my SolArk 15k.
I’ve just used the Black Friday sales to buy an EG4 Chargverter to charge them rather than using my 7.5k gas powered portable generator directly tied into the 15k. This setup was less than desirable for a couple reasons, it’s an older, non inverter (dirty) generator and the 15k really didn’t like feeding from it. The software in the 15k uses the generator as primary power to loads first then sends the overage to charge the batteries. This leads to surging and more distaste from the 15k having to use the generator feed. The 15k drops the gen if it surges and meanders out of range of the 60hz(which I have widened as much as their tech support recommends) 15k likes until it levels back out and then reconnects. Wash rinse repeat, this seems a pretty inefficient way to charge the batteries during grid down without PV input due to bad weather.
Long story short I got the Chargeverter to eliminate this situation, but now I’m wondering how to use it to charge more than one rack of the batteries?
Each of them is in an EG4 cabinet with its own bus bar and each has a set of 4/0 copper leads to the 15k battery bus.
If I mount the Chargeverter on one rack cabinet and connect it to the cabinet bus bars as per the manual, it should charge that rack, but I don’t think it’ll charge the other? Am I correct in thinking this? Or will the charging current feed thru to the 15k battery bus and be shared between the two racks?
Thanks for any thoughts on this.
