underdog5004
I have 4x 24v 200ah lifepower batteries. Was running a magnum ms2024, but now I've got a conext XW 5548 NA.
I've reconfigured the battery cables for series/parallel (2s2p), to achieve 48v nominal on the bank.
When the batteries were on 24v nominal, I was able to read their status using the communications cable.
Is it possible to make the XW 5548 and (now 48v) lifepowers communicate? I see signature solar just released a communications hub, but I think that's for the native 48v lifepower.
I have a conext combox.
Does anyone have experience with this specific use case?
I'm planning to expand the battery bank, either with 2x 24v200ah lifepowers, 2x 48v100ah lifepowers, or 2x 48v100ah LL batteries. Is there an advantage one way or the other? I know the 48v100ah lifepower is rated for 30a discharge each, while the 2x24v batteries would only give me 30ah discharge for the pair. Any other factors I should consider?
Thanks in advance for your help!
