How long have you had your batteries for? If they are new, you'll need to cycle them to calibrate the BMS.
If it's been in use for a while, then what is your depth of discharge?
The BMS inside is similar to a car. You need to perform maintenance on it every so often. Just to make sure that it stays calibrated.
