Hey all, I'm seeing alarm light on all my batteries in my LifePower4 battery array and was not seeing any charge indicators. It's been unusually cold here past few days so I suspect it is due to low temperature which I'm guessing the BMS disabled charging while there are low temps. I've seen from reading online that I could connect to the master battery and see what the warning/alarm is, but that communication is currently tied to my inverter instead. Is there any way to access these alarms via passthrough on the inverter comms instead of having to disconnect existing connection and use a laptop to direct connect to the batteries?
As for the low temps, I've seen on other posts of using seed warmers with a temp sensor and have already gotten those. Just using a space heater to direct heat to the batteries at the moment until I'm hoping the warning light will stop flashing.
Last question, would I need to reset the batteries for the warning light to go away, or will it eventually go away once the BMS sees that the temperature is in normal charging range?
