Just a quick question about expectations for PV battery charging.
I've been running for almost a month and I'm seeing expected PV input from my 7k array (sometimes a bit more) provided I have enough loads on the system (batteries + heat pump + lights etc..).
However today I'm seeing, no matter the level of sunshine, that my batteries are only charging up to a max input of about 2300 watts. No other loads today, just a batt bank that started the day at about 46% that needs to be recharged.
If I look at the EG4 LL v2 specs, it shows 100a supported by the BMS. With 3 batteries I'd expect to see more than 2300 watts .
In the EG4-6500 firmware there's a max charging and a max grid charging but I don't see anything about max PV charging.
Am I missing a setting somewhere or is ~2300 watts the max I should be seeing?
