Hello, this is my first post as I will be initiating my first home solar project (HOA now allows for panels on the roof as long as they aren’t visible from the street). I’ve been enjoying an Eco Flo Delta Pro and a panel for remote camping.
I did use the search function and did not see this specific question previously asked.
I do a lot of DIY, and as I’ve gotten older I’d really like to cool down my Texas garage during the day. I’ve lived in Texas 40 years, and there has been only one week I didn’t want to work in the garage due to extreme cold.
I’m considering the EG4 minisplit heat pump with four 400 watt panels mounted to the roof…and to power and run the minisplit only when the sun is out/during daylight hours (never connecting to any grid AC)
If running directly and only off the panels (never connecting to grid AC or a separate inverter/battery system); do I just ground the panels and mounting system to a separate grounding rod?
If I do decide to also connect to grid AC or eventually put together an all in one inverter + server rack battery, how does the grounding configuration change?
Thank you and preemptive apologies for any newb language.
