CaliSunHarvester
With some circuits now powered by solar, I thought we would not consume as many Wh. Last night, over a 13h interval, the meter moved forward by 36 kWh. We do have 3 electric water heaters on the property.. one is 19G @ 120V (outside, vacant house), one is tankless and nobody was there last night and the 3rd one is 80G @ 240V, with each (??) heating element being 4500W.
1) I think it's actually 4500W combined across them, since I only have 10AWG wire feeding them. Is this right? It cannot be 4500W per element.. that would be 37.5A per leg.
2) assuming the WH runs 4h a day, that would be 4 * 4.5 = 18kWh a day. This kind of fits the consumption.
What's the best way to measure the consumption over a period of time? Should buy a watt-meter? Like this for $100:
I rather not spend $100 to confirm that my water heater is the big consumer. It's an old unit.. 30 years old maybe.
3) what are my options to save electricity? With the 10AWG wiring, I cannot install a tankless electric WH. The location does not allow a gas heater - it's deep inside a basement, 40+ feet away from an exterior wall (cannot vent).
I looked at "hybrid water heaters". They extract heat from the surrounding room. Not sure how that would work in the basement location. Any suggestions? Going from 80G to 50G alone should save some energy, right? I don't know why they put that big unit in.. it won't fit through the door, I will need to cut it up to remove it. Wall was built after WH install LOL The house has 3 baths and 2 kitchens.. a recirc pump is sitting next to the WH; looks like from the 80s as well, was never installed.
Any other ideas? More panels to cover the greedy WH?
