I'm still trying to solve an electrical control problem. I've got a 100w/12v panel powering a small 12v water pump feature. I purposely eliminated a battery from the system because I don't want the pump running all night. The system consists of the panel, a 24v-12v transformer, on/off switch, and pump. In this configuration the system works perfectly, except the pump tries to push water when lower voltage is being produced. To give the pump a break, I added a low-voltage disconnect switch after the transformer that stops power supply to the load when the supply is less than 10.5v and re-connects when it returns to 12v. This worked but created too much on/off cycling, so I tried another that turns off at 10.0v and reconnects at 10.7v, but it just did a lot of clicking and the pump didn't pump. So the question is, what device will automatically shut down the pump at night and give the pump a rest when the PV is producing low voltage. Thanks.
