I finally completed my mobile solar system using Electrodacus SBMS0 and DSSR20. Everything is working well! It is a 280ah 24v system. As I look at system something strikes me (I'm a newbie-not an electrician, engineer, etc). First let me explain how battery is connect. Positive wire (2/0 about 1' long) from battery goes to 300a shunt then to 350a disconnect switch then to positive copper busbar. Off the positive copper busbar I have 300a MRBF fuse (changing to class t fuse when arrives) that goes to 3000w/24v invertor. I also have a 60a breaker connected to positive busbar that goes to Victron Battery Protect for DC electrical.
Question/concern: From the positive battery terminal through shunt and disconnect switch/busbar, there is no fuse protecting this wire/shunt/disconnect switch/busbar. This is how you're suppose to wire Electrodacus. Do I have a concern or is there a way to protect this run?
