jbkrntrprz
- Dec 18, 2020
- 136
I am a little confused on this subject. If the circuit is open ( deenergized ) is it protected from electromagnetic pulse. My thinking if given advance notice is disconnect all solar panels, open all breakers in main and critical loads panel including main breakers, disconnect all wiring going into inverters and disconnect all batteries and turn off. I believe turning off the batteries if they have built in breakers will deenergize the BMS. So does that protect everything or does the pulse flow thru the electronics even if the circuit is open? Haven't found a clear explanation on this.
