Realmaplesyrup
- Jul 24, 2020
- 51
How is an emp shield different than a surge protector. I see them advertised for cars as well. How would something that is not connected to the grid be protected from an emp?
How would a wire or device be shielded? A Faraday cage?Idk, a pulse from a large atomic device could be.troublesome...
Certainly a Carrington event striking today could cause mayhem...
Any unshielded wire or device connected to unshielded wire would suffer...
I have seen that phenomenon on the tip of my 45 ft sailboat mast in a storm at sea at night.Its not cool to see while hanging on to a stainless steel helm which is bonded to the mast a few ft away.. its right scary… but I’ve never heard of it hurting anyone. But I don’t know …..its been along time but I remember it being called St Elmo’s fire… but I may be wrong , I’m getting old..EMP just stands for Electromagnetic Pulse. It's a short, sharp spike of electromagnetic energy across a broad spectrum of frequencies. The most common EMP experienced is caused by lightning. Lightning induces massive currents in power lines, which act as long antennae, the voltage induced can easily be high enough to jump across switches and destroy equipment plugged in and turned off.
EMP is also used as a boogieman to sell stuff to worried people. The common story is that a nuclear weapon exploded in the upper atmosphere can cause a destructive power surge across a large area. The effects are often highly exaggerated for fear porn and marketing purposes. The amount of power induced in a device is proportional to the size of the antenna / power cord attached to the device. For example, an unplugged laptop sitting on your desk wouldn't be affected, a desktop plugged into the wall could well be destroyed, just as with a lightning strike. The idea that all cars would quit working, radios would all be dead, cellphones wiped out, etc. is just silly but makes for lots of knockoff books about TEOTWAWKI.
I used to spend a lot of time and money installing equipment to protect communications infrastructure, it's not hard to do with some planning, the equipment needed is widely available. I used to visit antenna arrays that literally had corona discharge dancing off the ends of the elements, 100's of 1,000's of volts of potential ionizing the air into a glowing plasma caused by static buildup around thunderstorms in the high desert, yet none of the electronics were damaged and just kept functioning year after. year.
I’m not the one to know this. But cables sheathed in a grounded conductor should do it, as would a faraday cage around a device.How would a wire or device be shielded? A Faraday cage?
So a man-made emp is incredibly powerful and destructive?Its pretty well impossible to protect most things from an EMP.
People have no idea how powerful these things are.
Its like looking at an automotive spark plug and saying a direct hit from a lightning bolt is really just like a spark plug, but bigger.
Just like a themonuclear explosion is just like a fire cracker, but bigger.
So just fit this little gizmo to all your expensive electronics and you will be fully protected.
Quite funny actually.
I did a little research on what are called e-bombs. Non nuclear pulse weapons.Yes indeed it is.
The electrical energy comes directly from a nuclear blast, and the electrical and magnetic fields produced are almost beyond imagination in thier power, just as the heat and blast energy is.
A specific EMP weapon is much more efficient in producing the electrical effects than blast effect.
But just about anything with transistors or semiconductors will be totally destroyed in function.
A bit of tinfoil or sheet metal is no protection from any of these effects.
I've been invited to a bbq tonight and apparently the invitee wants help with a faraday 'box'.A bit of tinfoil or sheet metal is no protection from any of these effects.
