OffGridInTheCity
Solar Wizard
OK, then you could start with a 5000w (or 6000w) all-in-one - and it would be as good as your current generator. This will give you experience.@OffGridInTheCity
... to continue...
As i stated the shop has no shore power. I have to use mu 5000w Generator or 3, 100 foot, extension cords.. I don't currently own a lot the stuff on list it's a more of over time I am wanitng to get those item. I had to borrow/rent/ or use at someone else's shop.
I am aware that the Welder/air compressor are up there as high needs and both are capable of being 240v machines. I even know where an air compressor is that is sitting unused that is possibly within that range. I was told to make an offer to the grand parents of a friend of mine.
Here's a 6000w MPP Solar example - https://www.mppsolar.com/v3/lvx6048/
Here's a 5000w Growatt - https://www.amazon.com/Growatt-Inverter-Charger-Controller-Lead-Acid/dp/B09HQPCLLV (but you need the 240->120v transformer as shown by @DavidPoz youtubes)
Not pushing either of these - just giving you mainstream examples that work off a 48v battery bank. There are many threads on this site on inverters to buy.
Next is that an off-grid all-in-one will need a battery and a way to charge it. You can use you're existing generator to charge / run things till you get grid and/or Solar Panels - but you need a battery!
How long do you typically run your 5000w generator on a given day to work in your shop - this can give an idea of the size of battery you need.
