The Enphase IQ8 micro inverters are connected in a string with the Q cable that has connectors built in at a set spacing. The connectors can be inserted in either of two orientations. Unlike a simple ac plug/receptacle that enforces a single orientation to ensure hot and neutral are connected correctly.
Can I assume that orientation of the connector doesn't matter?
This does make sense as each micro inverter senses the grid 240 volt 60 hz phase and syncs to it
thanks,
Scott
thanks,
Scott
