This is more paranoia than anything but I would like a system that doesn't have an internet-connected controller. I currently have an Enphase solar/battery system installed. The idea would be in a civic emergency where the grid here in SoCal was shutdown and let's assume Enphase was "ordered" to shut down customer DER's via the controller, I wanted to be able to bypass the Enphase system entirely (micro-inverters, Controller, batteries) and go Solar Panel to "alternate" Solar Charge Controller directly. For this I assume I would need to re-wire the panels, in a serial fashion, to a new Solar Charge Controller to which I can add (non-Enphase) batteries later.
I saw Will Prowse's review of the 120/240 EG4 6000XP and like that option for the price ~$1400. I would need some MC4 cable (est ~$300). I would have to re-organize a few panels. Our current (19) JA-Solar panels are rated 355W (38.5Vmp) with a max output in peak summer ~305W (they are 6 years old). This Eg4 can take 4000W (480VDC) per leg times two legs - 8KW total - more than enough. I figure I can string 10 panels in one leg and 9 panels on the other (total 19 panels) and still meet the 120VDC minimum to fire up the controller and be well under the limit of 480VDC/leg.
Assuming all that seems ok to you so far, I am looking at purchasing the MC4 cables and am confused on the sizing and length guidelines. If I string these serially, the current should stay the same, rated Imp 9.16A/string. So the off-the-shelf MC4 25' extension cables should handle this load, less than 10A each leg? I am guessing that the total length of each string needs to be added to the 25' MC4 extender length when calculating max current each string can handle?
If I am missing something, please advise. If this ~$2K "emergency prepper" proposed backup to the current Enphase system will work, then I need to decide if it is worth the cost. Trying to vet the solution here first.
Thanks in advance
Thanks in advance
