HI yet again!
I was reading through my Renogy Rove SCC manual, and it says that for the AGM batteries we have it will do an Equalization every 28 days. The data sheet for the batteries says Equalization voltage of 14.2 volts. The Rover manual says the Equalization is 14.6 for Sealed Lead Acid (for 2 hours). The manual also says 14.4 V for Boost (28.8 V for the 24 V system), yet I have seen it be in boost and hit 29.2 V.
Should I be concerned about the Boost having been higher than the manual states? It currently seems to be at the voltage the manual describes.
Should I be concerned about the Equalization being higher than the batteries 14.2? It doesn't seem like that will be too much if the boost is higher.
Definitely related, the manual says to make sure there is no load while the equalization is happening. I could see why having a lower voltage than boost would make sense with no load. Does anyone have any ideas on how to ensure there is no load when the Equalization happens other than manually turning off my inverter?
One final question:
The Data sheet for the AGM batteries has a discharge range of -4 F to 140 F.
It has a Charge range listed of 32 F to 122 F.
One of the main reasons I got AGM instead of Lithium is because we do live in a cold climate in the winter, as it was my understanding that Lead did well in the cold compared to Lithium. I'm a little concerned about the data sheet giving 32 F as the low charging point. Again, any insight is very much appreciated.
One final question:
