However it's been sitting at 1.2A for the past 32h and the voltage won't make it past 3.590 V
Stop charging. They're full (or something is wrong). Don't keep them at high voltage for that long.
One cell came down to rest at 3.362 V. The others are at 3.512 - 3.520V.
Share away, it will help others.I just purchased 16 of EVE 105 here in the US for $38 each with a good results after capacity test. I check the QR code and they have production of July last year if i don't recall wrong. Cells looks square no puff. Tested good.
Not sure if is ok sharing seller. I am new here in the forum. View attachment 192883View attachment 192884View attachment 192885View attachment 192886View attachment 192887View attachment 192889View attachment 192890
Any update?So far I've been asked to provide the QR codes of the batch under suspicion. Will do tonight after work.
Exactly there. Code checks out, that's not a problem. The problem is that the code is stickered and not etched, so I suspect a bunch of legitimate codes has been stickered to salvaged/out of spec/lower grade cells.Have you try checking the code here? https://www.gobelpower.com/lifepo4_decoder.html?code=
If they are legit peeling the sticker should have the qr code in laser right?Exactly there. Code checks out, that's not a problem. The problem is that the code is stickered and not etched, so I suspect a bunch of legitimate codes has been stickered to salvaged/out of spec/lower grade cells.
Understandable.Well, they said they've asked Eve about this and they are waiting for an answer. But I'm kinda running out of patience.
I'm happy for ya, really. Looking at the bolts yours are different and better looking. Mine are shorter and lack washers. I didn't give it much thought, but should have been a warning sign because they were different from the pictures. What kind of battery tester did you use?I just purchased 16 of EVE 105 here in the US for $38 each with a good results after capacity test. I check the QR code and they have production of July last year if i don't recall wrong. Cells looks square no puff. Tested good.
Why should I do that? The codes are supposed to be etched and readable through the transparent window at the top of the cells, no stickers and no peeling needed. Actually removing the top of the cell would void warranty. I suspect that there are either other QRs under the sticker or the original QR has been sanded. It's not me who should do the detective works. It's seller's duty to provide warranty and handle their supply chain.If they are legit peeling the sticker should have the qr code in laser right?
This one. https://www.aliexpress.us/item/3256...9204640.1005001458325206&gatewayAdapt=glo2usaI'm happy for ya, really. Looking at the bolts yours are different and better looking. Mine are shorter and lack washers. I didn't give it much thought, but should have been a warning sign because they were different from the pictures. What kind of battery tester did you use?
I just want the cells I paid for.
It is Chinese new year..Understandable.
Give it a bit more time. Try sending them an email tomorrow to just check how things are going on that front.
I would find it strange if a business that supposedly orders several containers worth over 100k € every month or so from EVE, would have to wait much longer to get an answer about suspicious cells with stickers instead of genuine laser-etched codes on them in their order.
Patience.
Technically speaking, a few hundred euros is not worth it for a business to noticeably degrade its reputation over it.
I have no horse in this game, at best maybe as a returning(or not) customer. And the fact I would like to see them do right by you.
You did not go cheap, you saved up and paid the price business asked for genuine A grade EVE cells.
I hope NKON does right by you. I was thrilled to find out there's a business in the EU that deals directly with EVE and offers Grade A cells.
Frankly, I would be disappointed if I could no longer consider them as an option.
China is closed for 2 weeks, no matter how big the order
