Zwy
Solar Wizard
I ordered 8 from Basen, all arrived in excellent condition, well packaged to prevent damage. Top balanced and capacity tested, had one bottom runner that shut down BMS at 278Ah but it took more according to my shunt on the recharge than 280Ah. No loose terminals, I did use different studs because I wanted longer and made my own bussbars because of my compression fixture. I am satisfied with the cells I received from Basen. Why not wait until they arrive, check the condition and do the capacity test if they don't have any damage?TdKo, I just brought from them too. I hope mine is in better shape. Were Alibaba able to help you? Did the battery work to specs? Safe to use? Sorry, I have to ask because I want the battery to be at least safe when I am not around. Is there any good test to confirm the battery is safe that I can do when mine arrive?
