Ok I have 32 280ah grade A eve cells set up as 2 48v batteries each with a 500amp Daly smart bms and a growatt spf 12000t dvm-mvp inverter also a Victron smart shunt
First question of many to come is charging current on the inverter can be set from 10-180amp for combined charging power from ac and solar question is is this something I should change depending on how I’m charging? Or is it set and forget? I will be charging with a generator (9500 Westinghouse w/50 amp plug) and to start only 6 solar panels till the rest of the array is built 3s4p in each input eventually
I will have many more questions thanks to anyone who can help
