Delta temp for a hot water tank is more like under 30 degrees C. Your results are around doubled, so more like 10kwh for the size tank you referenced. That is if you have a tank filled once a day with cold ground water and thus an extra tank.What's a normal tank? And what temperature differential?
From a cold start (e.g. 10C) a 320 litre tank requires about 20kWh to raise water temp to spec (60C).
In Australia we have several solar PV diverters for hot water systems:
Hot Water PV Diverter Comparison Table
View a list of all the solar hot water diverters on the Australian market we know of, plus pricing information and technical specifications.www.solarquotes.com.au
I'd imagine similar would be available where you are.
You were talking about the amount of energy stored in a tank of hot water, not the daily energy required to keep it hot. These are quite different things.Delta temp for a hot water tank is more like under 30 degrees C.
I don’t think you’ll be off grid with a Tesla Powerwall. It has to phone home every three days. Does not sound off grid friendly. Homemade with lfp batts or generac May be better.I am planning to go off grid. I will had a tesla battery system. Do I have to do something with the excess energy if the batteries are full. Do I need some type of dummy load and how would I switch over to it.
why would nuclear need dummy load... it is just steam and you can bypass the steam going to the turbine strait to the cooling towerI can’t speak to the TElsa power wall, but with solar and batteries, you don’t need a dummy load.
If you had wind, you would need a dummy load. For when I looked at wind, the dummy load was built in so this load was a component added on to the system to make it transparent to you. Years ago I saw some people who used a 500 or 1000 watt space heater As a dummy load, but the newer systems I looked at these dummy loads were components were built in to the windmill that you did not even notice them.
Hydro seems to need the same dummy loads, but not many people can use that. Nuclear power needs a dummy load also, but don’t know anyone using that as a home system.
Perhaps. I’m certainly no engineer. Nuclear power tends to provide really cheap electricity at night. Perhaps its to send the steam to the turbines instead of the air. My point to the post was solar doesn’t need dummy loads.why would nuclear need dummy load... it is just steam and you can bypass the steam going to the turbine strait to the cooling tower
I would not like to live near a nuclear plant that has to let off steam as it is radioactive at times.why would nuclear need dummy load... it is just steam and you can bypass the steam going to the turbine strait to the cooling tower
Hydro dummy load is to pump the water back to the reservoir.I can’t speak to the TElsa power wall, but with solar and batteries, you don’t need a dummy load.
At 50kWh/day you must be growing weed or pouring anvils Please tell what you do with all that juice.extra solar...hehe... people always have very different setups and it certainly shapes they view point.
for example, I have a small place and consume about 50Kwh/day...so the first thing I thought reading the above was "Wow, that guy much have a huuuuggge solar panel farm to have extra power"
it doesn't let steam into the air.. it redirectd it to the cooling tower, lake, ocean.. what ever method is being usedI would not like to live near a nuclear plant that has to let off steam as it is radioactive at times.
It is surprising how much extra power there is with a solar system. I heat all the house water with only excess PV, be it just a few watts or hundreds. It can be as short as just a few seconds, but it adds up over the day. Just random collection, hot water has lowest priority.
Those red and whit towers are for off gas, dispersal before it hits the ground. I climbed one in Japan, lucky I never got caught. It is a shame bean counters destroyed part of that country. There was no damage to reactor. They put backup generator too close to ocean. First thing wiped out was fuel tank. You don't know how many events have occurred which have gone unreported.it doesn't let steam into the air.. it redirectd it to the cooling tower, lake, ocean.. what ever method is being used
It would be wiser to just add them into your systemIs there a way to divert extra solar energy into another battery bank that can be used as backup storage for those cloudy days?
My system isn't that large but I use around 20-25% per day. This runs my freezer and basement lighting 24/7. I have 600 watts of solar, Victron 250/60 charge controller and a 2000 watt pure SW inverter. I was thinking if I had two more batteries on stand-by I could use them to recharge my main battery bank for those cloudy days. Does anyone do this? Or would it just be wiser to just added them into the system? I enjoy building and experimenting with different ideas. I am curious how people will respond!
ThisOr would it just be wiser to just added them into the system?
With wind power you need to do something with extra energy. Solar you do not.
