Hello, I hope this is ok in the general area. I recently got my F150 Powerboost with the 7.2KW ProPower onboard. When I plugged into it, I instantly got a ground fault. Looking on some other forums, people trying to do this to power their home have required a transfer switch, but I thought maybe there was an easier, cheaper solution for me since I do not have grid power. My shore power is the generator. Prior to the F150 I plugged into inverter/generators which would charge my batteries and run the cabin at the same time without issue. What I've learned is that they worked because they were all floating neutral generators whereas the ProPower is a bonded neutral. Since my cabin is bonded as well it's creating a ground fault loop? I will try to explain my configuration and if anyone can lend some insight it is greatly appreciated.
I have an L14-30 240V plug that plugs directly into generator. That plug is wired into my Magnum MS4024PAE inverter. The inverter then connects to my battery bank, and to my electrical panel inside the cabin.
The solutions I have been given so far have been a neutral switching transfer switch? Or disconnecting the ground wire from the cord that plugs into the generator which I know is not a good idea. I don't know a lot about a transfer switch, but I don't love the idea of having to switch a bunch of breakers every time I want to switch to generator power. If my battery bank is getting low and I'm going to turn on the oven for a bit, or run a coffee maker I just fire up the generator for 20 minutes and then turn it off and go back to battery power for lower consumption. I thought this ProPower system would allow me the same convenience.
Thanks in advance for offering some input on this.
